replaced bulb, still no light
so my lights went out, on my rear passenger corner marker and the right side of the license plate light. i replaced the bulbs but still no light, is there a fuse or something thats seperate for these 2 lights? or if its wiring can i wire them to the other corner markers?
you could just be having the same problem i had
went you removed the blubs did they look rusted on the ends if so your getting to much water in the lights and your terminals are corroded and you just have to clean them up a bit that should work.
or you can get creative and wire them in to your turn signels then they'll flash when you turn
Reaper
Greg
Reaper
Greg
![Image](http://i81.photobucket.com/albums/j214/reaperofsouls2001/winterx-90.jpg)
