RPM Gauge screwed up
- MX-3 Money
When I turn the key to the on position the rpm needle moves to about 250 rpms and when I'm driving the car around the rpm's are about 500-700 higer then they should be. Anyone had this problem, maybe its my rpm gaguge and i should replace it?
1993 MX-3 GS 5 spd, KL-ZE swap, kl31 ecu, 110 amp alternator, Unorthodox Underdrive Pulley, SSautocrome headers, High flow cat, Pacesetter high flow cat-back, B&M shortshifter, Clear Sigs/Sides.
- MX-3 Money
The distributor has 2 connectors - unplug the 3 wire connector and turn the key to on position. If the gauge shows zero then maybe the disty is going bye bye. If the gauge is still screwed up - then its either the gauge itself or the wiring from the disty to the gauge.
94 Mx-3 Precidia
- MX-3 Money
well it happened after i was replacing my glow gauges so i don't think its the disty, plus i just replaced it last summer.
You have your work cut out then - In the future it will be much beneficial if all necessary & critical information is presented first while asking the question.MX-3 Money wrote:well it happened after i was replacing my glow gauges
94 Mx-3 Precidia
- MX-3 Money
the fisty has one line comming for the tack.. tech the amount of voltage tehre as u rev it.. however i forgot how much it should read.... lol..
-hec
