EGR TEST
The EGR valve is actuated when it gets fed vaccum. Under certain conditions it wont be functioning.
Did you fail an emmisions test by chance? a high NOX reading tends to be the EGR not funcitoning, if anything remove it from your car and see if its clogged and that the diafram actuates when under vaccum.
-torp.
I don't own a Mazda.
