easy no bake way to remove headlight grime.
mazdamx3sohc
Post by mazdamx3sohc »
Mother's aluminum and mag polish™
Before:
After:
kudkudniyog
Post by kudkudniyog »
COOL
mazdamx3sohc
i love it. thanks alex.
jschrauwen
Post by jschrauwen »
:2thumbsup:
mazdamx3sohc
thank yah.
JWMX3
Post by JWMX3 »
looks good... meguiars plastix polish gets the same results
mazdamx3sohc
yea, this was given to me for free by kudkudniyog, above. thank you.
CLPCLD
Post by CLPCLD »
That's a ridiculously good tip. I may have to try that on my friends prelude. Do you know if it gets hazy again pretty quickly or anything along those lines? It would be interesting to see if it helps for a longer period of time than the plastic polish stuff...
Silver 1997 Ford Probe GTS - 176whp de
Crystal Blue 1993 Mazda MX-6 LS
kudkudniyog
I tried both plastic polish and this mother's aluminum polish. It pretty much gives the same results but the mother's aluminum polish can be used on plastic (not recommended by the manufacturer, however it works) and aluminum. So I keep only one product for both plastic and aluminum insted of two. I also used the product for polishing my gauge cluster lens (plastic cover). I love this thing. I always keep an extra tub handy. I use it on all of our cars.
reprobation
Post by reprobation »
In my opinion, NOVUS plastic cleaner still works best - i bought mine on e-bay for about 13 bucks shipped. Its a 3 step process, but the stuff looks like glass when your done:
1994 RS DOHC, Modified Cold Air Intake, Clear Corners all around, Black Altezza Tail lights. Blue cold cathodes in driver / passenger foot areas. Lowerd on Evotion Springs (1.75 drop F/R) with KYB GR2 struts. Sitting on 17x7 (40 mm offset) 5 Spoke rims with KUHMO 205/40/R17 Tires.
http://www.cardomain.com/ride/807557
illapino
Re: easy no bake way to remove headlight grime.
Post by illapino »
mazdamx3sohc wrote:Mother's aluminum and mag polish™
Before:
After:
by no bake do u mean you didn't split it open and wipe the inside too?
mazdamx3sohc
yea pretty much. not yet anyways. as you can tell i have a broken bulb inside that light assembly still, it was a 50 dollar bulb, blah i was kind mad, i got a new one in there though.
Custommx3
Site Administrator
Post by Custommx3 »
Pretty much any abrasive polish will work. Ive even used Polishing compound and it works.
mazdamx3sohc
although pretty much anything will work, its amazing, cus there has been times where i sat there scrubbing the hell out of it and nothing even came off even a little bit.
Post by Josh »
i think out of everything i have tried, i have seen the most improvements out of Novus. but the best and fastest way is always with a buffer and a 2 speed drill.
Return to “Appearance”
