Little vid of my ZE
solo_ryder
Little vid of my ZE
Post by solo_ryder »
Made a small vid on a closed backroad of the acceleration of my ze, I am still running the k8 im and ecu.
KLZE Power! I think its slow :S
Let me know your thoughts.
Re: Little vid of my ZE
solo_ryder wrote: I think its slow :S
Maybe it's because your e-brake is engaged :P
Talon_66
Post by Talon_66 »
Its been 10 months since I drove my KLZE Mx3. I couldnt tell you how that compares, Im too used to the Eclipse now.
But I can tell you I was in a KLZE Mx3 with Exhaust and Intake, and it had no pull compared to mine.
Good job man! Hope you enjoy
06 Eclipse GT *Sold*
08 Evo X GSR *Current*
solo_ryder
LOL I pull it up one notch so the gay driving lights arent on
XxantwawnxX
Post by XxantwawnxX »
0-60 in 6 seconds i say thats about right. (ya started going at 3 seconds
reached 60 at 9.
so from 9 secs (stock) to 6.
solo_ryder
XxantwawnxX wrote:0-60 in 6 seconds i say thats about right. (ya started going at 3 seconds
reached 60 at 9.
Yea, looks about right, i guess that is not bad, anyone notice a power diff from using the kl36 ecu amd curved neck IM over the k8 setup?
mx3autozam
Post by mx3autozam »
MY KLZE was a bif different from the k8 but tsill i didn't think it was as quick as other ZE's i have been in..I then swapped over the curved neck manifold and it opened it right up. I still need to get the KL31 or 36 ecu.
MY SE also has warped heads so its got a little low compression. I'm working on fixing that right now.
John
93 Mazda MX3 KLZE Turbo
mx3autozam
If you wanna see one fast KLZE check out this video
http://videos.streetfire.net/search/mx- ... 805CE8.htm
http://videos.streetfire.net/search/mx- ... A496E2.htm
That car also ahs the same engine mods as my car. S once I egt my heads back togetehr i'm hoping for soem pull like that.
John
Macen
Post by Macen »
solo_ryder: Looks pretty fast to me. :2thumbsup:
Black '93 GS-RL KL-DE
White '95 RX-7 Type R Bathurst
http://macen.nullnet.com
Custommx3
Site Administrator
Post by Custommx3 »
Shifting a bit late :)
sounds good.. and somewhat familiar :)
mazdamx3sohc
Post by mazdamx3sohc »
all of your bad lights are on, and your slightly over heating. lol
solo_ryder
mazdamx3sohc wrote:all of your bad lights are on, and your slightly over heating. lol
No, as I stated I pull the ebrake one notch as I hate the driving lights. The guage is always that high, with my k8 or ze. proly bent it when I put in the guages.
mx3autozam
Thats not slightly overheatging. My MX3 and a friends MX3 we both have ZE's and sit a tad past the middle.
John
XxantwawnxX
My ze has NEVER sat past the middle a day in its life.
solo_ryder
Yea, I have noticed it was like that before the guages as well now that I think about it. I have seen another mx3 like that as well, oh well, I have never had a problem with overheating so I guess it is ok.
