clear side markers
clear side markers
i know that i've seen some guys have the front clear markers on the side, but i just can't find any. i see on ebay they have the front markers for signals, but i was wondering if they also made them for the rear markers?
Yes and No.
I believe technically there isn't, but those do have the, get them from the Miata. My memory may be wrong on that, but in either case, they don't fit 100% perfect, the bottom part of the marker doesn't fit flush, sticks out a few milimeters, but can be trimmed to fit, but most don't, why I don't know, maybe it's difficult, I don't know, but that's what I know.
- mr1in6billion
You memory is 100% right. Only one side of the marker is off, and it's only off by about 2mm, so you can only tell if your head is about a foot away. I haven't trimmed mine down yet because i'm lazy and it's not like it looks bad.Nd4SpdSe wrote:Yes and No.
- jschrauwen
http://www.rspeed.net/miata/item.asp?de ... od=602-150jamestakay wrote:what year miata is it from? thanks.
Have you tried corksport.com yet?
If your talking about the side marker that is behind the front side marker/turn signal - then corksport has one for around 35 i believe..its what i currently have on my car - direct bolt up with lense and housing - not moding need it.
-Chris
-Chris
1994 RS DOHC, Modified Cold Air Intake, Clear Corners all around, Black Altezza Tail lights. Blue cold cathodes in driver / passenger foot areas. Lowerd on Evotion Springs (1.75 drop F/R) with KYB GR2 struts. Sitting on 17x7 (40 mm offset) 5 Spoke rims with KUHMO 205/40/R17 Tires.
http://www.cardomain.com/ride/807557
