car died, won't start need help
sinhron
Post by sinhron »
Hi there,
A week ago my car died, so I figure it is the distributor again, so I went and picked up a disty from the junkyard, put it on, and it did not work. so I tought the disty is bad. I proceeded with the HEI mod and finished it, but it is not working again.
How should I check if the HEI mode is working properly, and one more question is about the self disgnostic , is there anywhere I can read some instructions on it? and maybe what the error codes mean ?
Thanks
Custommx3
Site Administrator
Post by Custommx3 »
GND to TEN , read the codes.
They are in the online manual. Link is on the front page of this site.
sinhron
Post by sinhron »
could you direct me on what page can I find this codes please ?
twoie
Post by twoie »
main page left hand side.
twoie
BSinnest
Post by BSinnest »
when you put your key in and turn it. do you get power to the dash and such? if not.. then look under the dash and find the relay by the clutch pedal with black and blue wires going to it, and replace it. this happened to me. changed it, and fired right up.
Thats all i know.
Brian
