how to plug vacuum?
Matrix733
how to plug vacuum?
Post by Matrix733 »
how or what do you guys use to plug unwanted/unused vacuum lines?
Knowledge Is Power ; Keep Cracking
PWRD_BY_HKS
Post by PWRD_BY_HKS »
it depends what it is... is it a little nipple....or cow size nipple.....use tape(its a mexican thing to do) .... a screw a hose ........anything
jdmx-3 KID OF THE Image
VICTORIA RACING
ZE PERFORMANCE IN 915 TX
Kl01-ZE,Kl31 ecu, millenia manifold, ngk plugs, ngk wires, probe tranny/ and clutch (stock), VortecH FMU 12:1, Aeromotive AFPR, Tial .38mm Wastegate w/ 4lbs spring, Walboro 255 pump, AiResearch T4, 3" down pipe, GODSPEED manifold, Spearco Boost Gauges, BF Goodrich G-force drag radials.
14.8 1/4 mile all motor untimed on boost.
fieromx3
Post by fieromx3 »
well i know u can buy little packs of vac line plugs its just a lil line that plugged on the one end and u can buy packets with all diff sizes from big to small to fit all ur needs...down here at crappy tire its like 5 bux for a packet
93' MX-3 GS-ZE
14.4 @ 96.7
14.5 @ 97.2
Matrix733
Post by Matrix733 »
thanks fellows, am plugging small vacuum lines, egr etc. will check those package plugs out when the store open, for now, where did i put that darn tape, lol :)
jschrauwen
Post by jschrauwen »
Sometimes a golf tee can be used to plug a vaccum line hose in a pinch .... short term only.
