can u build ur own phenolic intake gaskets?
jarro
Post by jarro »
does any know or has a page were it shows how or what to do to build my own phenolic gaskets.i would like to know if thats cheaper than buying them off the internet,or a store.
garfy1981
Post by garfy1981 »
i had a set of spacers and sold them off but on inspection and if you had the pattern i could definately copy them.
i work as a electrician and when building switch gear we use a sheet product called paxoline this is a brown high temperature material which which we fit between switch gear and cable trunking, im 99% sure is what the spacers are made of, because it looked identical.
A a table scroll saw and about couple hours of work and i could reproduce them easily.
Dont know if electricians in the u.s use this on their switch gear but if you know a industrial electrician its worth asking. Over here its something like £75 for a sheet, but its about 1.5m x 1.5m.
But then of course the spacers could have a patent on them so a mass produce copy is prob not a good idea :roll:
2.5 Ze straight neck, blitz intake, mazdaspeed engine mounts, fidenza flywheel, CM II Clutch, KL-36 ecu, Magnecor 8mm Leads, Battery Relocation. Hotshot headers, 2.5 mandrel bent stainless exhaust, hi-flow cat, Speed hut dials, custom coilover set up. Custom willwood big brake conversion.
