Say on a KLDE, what is easier to install?
I know its a stupid question, but a MX3 does have a small engine bay and from what I hear, I will need a sometype of transfere pulley/case thing. Forgot what it was called
So I hear a rebuilt M45 Supercharger should only cost me about $300. I am guessing with a Fuel Management System, fuel injectors, intercooler and fuel pump, the total cost should be about $1000.
In other words, as far as costs:
S/C > Turbo
A supercharger or a turbo?
Whats easier to install on a V6, SuperCharger or turbo?
2008 Mazda 3
1993 MX3 GS
1993 MX3 GS
- babyblueMX3
I think it's the opposite
turbo>sc as far as cost is concern.
It all depends if YOU are building the pipes or buying them. But either way turbo will probably cost you more but has more potential
RIP 400whp ZE-T MX-3
- mitmaks
supercharger in most instances will be cheaper. A centrifugal s/c would be better than turbo IMO. It all depends what you like though. Do you like instant power or snappy turbo power. Do you want to highway cruise or just 1/4 race.
01 Lexus Is300 (LS2 Project)
93 Mx3 SE 2.5 KLZE (sold it)
that one doesn't fit in a mx3.
I'm working on a shaftbased kit at the moment. It's planned to be finished next month. I this kit gives good performance results it will go in production.
daytona blue MX-3 2.5L V6 KL-ZE, KL31 ecu, koni lowered 40mm, freeflow exhaust system (decat), centerforge race clutch, cold air intake Dynamik, front and rear strut bars reactive, OBX race headers, Akebono pro act ceramic brake pads, Techna fit steel brake lines, zimmmerman crossdrilled rotors, reverse glow gauges, spinner gauges, topmix front lip, pakfeifer skirts, pakfeifer difussor, pakfeifer wing, inverted scoop bonnet , 17" bsa rims, etc
