I am on a budget but am upgrading my audio system. i don't want to spend alot but i want a decent system. Right now i have a 10" pioneer sub in my trunk and i am actually very suprised how much it pounds! anyways. i recently upgraded my front speakers to these 6 1/2" pioneers.
http://www.pioneerelectronics.ca/pna/pr ... 28,00.html
They sound pretty good coming straight from my deck. Its a pretty good deck but not a very big brand. its called KOSS. the deck puts out 50w a channel. so that is my system right now. My brother gave me an old pioneer amp that i know very little about. it is 2 channel and says it is 35w RMS each channel. my question is would it be worth amping my front speakers? (eventaully rear too) I would install the amp under the passenger seat. If you do think it will make a difference what would the difference be? like more bass from the 6.5's or better sound over all?
-HB
Is it worth it?
Is it worth it?
I got myself a 93' mazda precidia GS. mostly stock but i looking to change that.
Re: Is it worth it?
HB2k wrote: the deck puts out 50w a channel.
If the deck output (50w) is the RMS value - then there is no sense in "amplifying" 50w into 35w.HB2k wrote: it is 2 channel and says it is 35w RMS each channel.
If 50w is the peak value and the nominal value is somewhere in the 10's then it would make (slight) sense to have an amp. But before you connect it you have to make sure that amp's peak output is less than or equal to the speakers max power or you might have to listen to in low volume/bass only.
94 Mx-3 Precidia
- mr1in6billion
Re: Is it worth it?
There is no way a deck is going to crank 50w rms. Companies always try and make their s--- seem better, so they are going to put the max value on there.ariesdude wrote:HB2k wrote: the deck puts out 50w a channel.If the deck output (50w) is the RMS value - then there is no sense in "amplifying" 50w into 35w.HB2k wrote: it is 2 channel and says it is 35w RMS each channel.
The speakers and the amp are both 35w rms, so they are well matched. Considering the amp is free you might as well use it. The added power makes for better quality music.
hahah
lol you could by the lightning bolt amp... its got 100000 watts lol
