![Shocked :shock:](./images/smilies/icon_eek.gif)
#1 there is a vacuum? Line on the top of the throttle body my k8 did not. Where dose this go to?
#2 i installed my new clutch and my old 5spd tranny and i noticed that little clutch lever that the master clutch cylinder pushes is very easy to push back and forward with no pressure is this normal?
#3 strange wire: i noticed on my old k8 there is a wire that goes from near the coolant filler down into where the fuel rails are. It has a red and a black wire. But on my klze it did not have one? However on the klze i noticed a wire coming from under the fuel rails but coming out near the intake side of the engine it was cut off and it looked only like a red wire insulated with silver wire in a black sleeve. Is this the same wire? Can i just put a new clip on it?
#4 where is a good place to run my cai to? I hear some say in the space below the coolant overflow is good and some say its bad, where would be the best?
#5 on the klze there is a vacuum or a breather plug on the back left of the IM and on the k8 there is one there but its plugged IM guessing i plug the one on the klze?
