whre is egr valve located 1994 1.8 litre?
the check engine light comes on when highway driving . checked code and comes up egr is this the valve itself or a sensor and where exactly is it located thanx
Have you looked at this?
http://eunos30x.com/info/CEL%20Codes%20 ... mplete.pdf
As far a I know the solenoid is mounted on the air box (don't take that as gospel - I'll look it up if you need it - let me know).
- solo_ryder
