Misfiring?
- solo_ryder
Misfiring?
hey, got my ze in with a k8 mani and the k8 ecu and je50 VAF (hope that is the right combo since I havent yet installed the Im from the ZE) and it seems to be misfiring at lower rpms, the timing is dead on and the disty is from my k8 so I know it works. I also changed the spark plug wires and that did not make a difference, the sound seems to go away at higher rpms and it is smooth, could it be a vaccum leek or a TPS issue? May it is the ecu that I am running or the VAF combo... Its just really rough, any ideas guys?
yes, that IS it, wrong computer. I had the K8 computer on my KLDE for awhile, man was it bad. It was dog slow and sounded like it had a cam in it and the car wasnt tuned right!! At high RPM's it ran way to lean and cut out at 5000 RPM's like a turbo car with too much boost. Stick in a probe computer and mass air and you should be good to go. ![Wink :wink:](./images/smilies/icon_wink.gif)
- solo_ryder
no way, not good, not enough fuel delivery. Think of it this way, your 2.5 is getting the same amount of fuel as your 1.8 was. It cant work that way, at least not well. Just trust me, you arent getting enough air or fuel. I would say you are probably losing 15-20 or so potential horsepower between all of that that you have going on.
When I got mine running right, it was night and day difference, almost like a small nitrous shot.
- solo_ryder
- XxantwawnxX
I had the k8 ecu on the ze for years np at all..cept for being rich.
- solo_ryder
- solo_ryder
I'd say it's because you're still running stock injectors. I ran the K8 ecu, Je-50, K8 IM for a year with no problems exept it ran rich. It was slow and torqueless till I swapped out the fuel rail and injectors from the ZE IM. Mind you having the ZE IM and proper ecu will make you think your engine used to be crippled
Your ecu will still think your running the smaller 170cc injectors, so you'll be pumping more fuel. Try swithching the whole rail unit with injectors still in and see if that helps.
![Shocked :shock:](./images/smilies/icon_eek.gif)
From KL-ZE Strait neck KL31 MX3 to RHD 300zxTT
Isn't the ideal ZE set up a ZE block, kl-31 cams, MS8 intake manifold and a kl31 ECU ?
1993 MX-3 GS-SE -> Leather Interior, HEI Mod, Blaster 2 coil, NGK spark wires, Cold Air Intake, Underbody kit, Strut bar, Iridium plugs, Phoenix Gold amp 400w, Bazooka 12" sub-> 62,000 miles and still going ? Amazing lol..
- solo_ryder
Yea, well, I am looking into getting a MS8 IM from another member on this board but they dont pm me back, then I can run my kl36 ecu,RacerX wrote:Isn't the ideal ZE set up a ZE block, kl-31 cams, MS8 intake manifold and a kl31 ECU ?
Yea well u were running a DE, and I am running the k8ecu/im and je50 vaf so those are all the right combos, it sounds like it is running on 5 cyclinders that is all, will check the plugs today.2.5mazda wrote:stick that computer in, I am sitting here telling you I had the EXACT same problem. Make sure the mass air matches the computer and you are using the correct injectors.
- solo_ryder
