For sale is a 1992 Mazda Mx-3 with an escort gt motor and transmission swap. It has a push button start, brand new axels, wheel bearings, brakes, all seals and gaskets were changed in motor, new thermostat, water pump, tires and struts. Car starts up and runs great but clutch is BAD. Clutch will no longer engage. So car must be towed. I recommend getting a high performance clutch anyways. Motor itself has 71,000 miles on it. Body is in less then perfect condition but I used it as a sleeper and once you add the turbo it will be perfect. I no longer have a garage at my disposal so I must get rid of it. Remember MUST TOW CLUTCH IS BAD. I'm throwing in a cold air intake along with it as well.
![Image](http://i19.photobucket.com/albums/b185/alexoster/DSCN0620.jpg)
![Image](http://i19.photobucket.com/albums/b185/alexoster/DSCN0622.jpg)
![Image](http://i19.photobucket.com/albums/b185/alexoster/DSCN0618.jpg)
![Image](http://i19.photobucket.com/albums/b185/alexoster/DSCN0616.jpg)
![Image](http://i19.photobucket.com/albums/b185/alexoster/DSCN0615.jpg)
![Image](http://i19.photobucket.com/albums/b185/alexoster/DSCN0617.jpg)
