f%6k!!!
I stiil cant remove the radio :S
see.. heres the problem with details:
The problem is that the release pins (U-shaped pair) refuse to engage the release mechanism on
the left hand side of the unit. I slot the pin into the holes but it
seems to push in much further than it should and hence won't release the
unit. I've fiddled around for hours (well, ok, about 15 minutes
![Smile :-)](./images/smilies/icon_smile.gif)
) but
I think something must have either jammed or got broken.
Does anyone have any ideas? Or am I going to have to remove the whole
front fascia and attack the head unit from behind? (If it's possible to
remove the fascia without removing the head unit first!)
