HELP ? Does this steering wheel contain airbag ? HELP
Sunday i am going to trip 300 miles to see this car, and it is possible that it will be my next car.
I just need to know if this MX3 has airbags or not ...
sure does look like one. If you pop your hood and look at the front of your car jsut behind the bumper cover. If you see a little square box yes you ahve air bags. But that wheel looks like it does not sure tho.
1994 toyota supra single turbo
1994 Mazda MX-3 KL-ZE
its pretty sure its not, push the center, if your horn honks its not. the ones with the airbags had the horn buttons on the side from the ones that i have seen, plus you would have had the passenger side one as well.
Generally when a car has air bags there is a sticker on the door glass or an SRS emblem somewhere on the wheel. The other thing is there should be an airbag light on the dash when you turn the key on.
