Page 1 of 2
1.6L DOHC cams
Posted: April 25th, 2006, 10:34 pm
by Boris
After finding out that I can do a head swap on my sohc 1.6L, I am pretty sure I will end up doing it.
A few things I wanted to find out before I start looking for a head is if there's a place other than gude.com that I can buy performance cams, and even valve springs.
I know corksport sells 1.6L DOHC 323 and miata cams, does anyone know if those would fit an mx3 head?
Thanks,
Boris
Posted: April 25th, 2006, 10:40 pm
by Bochek
if i remember right, miata cams work, only you have to put the intake in the exhaust and the exhaust in the intake.
Bochek
Posted: April 25th, 2006, 10:57 pm
by Boris
cool, is this a pretty common swap?
Bochek,
I see that you're in Burlington. I'm in Oakville, what highschool do you/did you go to?
Posted: April 26th, 2006, 6:41 pm
by Boris
Well I've found a dohc head, all I need is some confirmation that miata cams or 323 cams will work. mx3 dohc cams would be the best if anyone knows where I could get em.
Posted: April 26th, 2006, 7:14 pm
by Joey's mx
Yes they do fit..i am running stage 2 miata cams from intergral cams right now!!!
Posted: April 26th, 2006, 8:35 pm
by Boris
Awesome! That's really good to hear...
Does it matter what year I get? Like would 1990-98 cams be different from 1999-2005?
Also, pretty much all the internal stuff (pistons, for example) will be stock...would buying a set of corksport cams be ok? Is there anything else that I should swap?
Thanks a lot for the help...maybe my mazda won't be so slow soon
Posted: April 27th, 2006, 1:05 am
by jorcool13
why is it that invert miata cams in our cars? Is it about the duration and/or the lift or the physical design?
Posted: April 27th, 2006, 7:31 am
by Bochek
Boris wrote:
Bochek,
I go to school @ MM Robinson. Cant wait to be done school lol.
im not exactly really sure, but i think it has to do with the direction the gears are cut...
But dont quote me on that. It could be just about anything.
But if you get a miata head, then i assume you would leave them where they are.
Bochek
Posted: April 27th, 2006, 8:51 pm
by Joey's mx
you have to invert them because they are opositer in the miata being it is a rear wheel drive car!!
Posted: April 27th, 2006, 9:15 pm
by Boris
sweeeet!! Can't wait to start buying parts and putting this head together...
Posted: April 28th, 2006, 6:19 pm
by cjthor
Since when can you put a DOHC head on a SOHC block??
Posted: April 28th, 2006, 6:36 pm
by Boris
http://www.mx-3.com/phpbb2/viewtopic.php?t=50988
Supposedly it's possible... I'm gonna go to the mazda dealership and order both head gaskets I think. That way I'll be able to compare them, just to make sure everything lines up before I blow too much money on a dohc head buildup. I'll buy one of the two head gaskets and probably pay some sort of handling fee for the other one. It'll be worth the extra $20 or so for the piece of mind that the swap will work.
Posted: April 28th, 2006, 6:48 pm
by cjthor
Boris wrote:http://www.mx-3.com/phpbb2/viewtopic.php?t=50988
No no no...its NOT possible. If you read...they say you can POSSIBLY swap out a 16 valve head for your 8 valve head. the DOHC head is wider, oil and water ports are different, distributor is different, just to name a few. Sorry!
Posted: April 28th, 2006, 7:00 pm
by Boris
hmm. Well that sucks... I guess I could try getting a full dohc engine then. I'm assuming a sohc centerforce clutch will work on the dohc 1.6L...
Posted: April 28th, 2006, 7:04 pm
by Boris
I'd still like to find out for sure whether the head swap is possible though...according to josh the only difference is some oil ports which wouldn't be hard to solve at all. If anyone knows of any places in Ontario that actually have mx3 gaskets IN STOCK let me know...
