1.6L DOHC cams
1.6L DOHC cams
After finding out that I can do a head swap on my sohc 1.6L, I am pretty sure I will end up doing it.
A few things I wanted to find out before I start looking for a head is if there's a place other than gude.com that I can buy performance cams, and even valve springs.
I know corksport sells 1.6L DOHC 323 and miata cams, does anyone know if those would fit an mx3 head?
Thanks,
Boris
Thanks,
Boris
if i remember right, miata cams work, only you have to put the intake in the exhaust and the exhaust in the intake.
Bochek
Bochek
Awesome! That's really good to hear...
Does it matter what year I get? Like would 1990-98 cams be different from 1999-2005?
Also, pretty much all the internal stuff (pistons, for example) will be stock...would buying a set of corksport cams be ok? Is there anything else that I should swap?
Thanks a lot for the help...maybe my mazda won't be so slow soon
I go to school @ MM Robinson. Cant wait to be done school lol.Boris wrote:
Bochek,
I see that you're in Burlington. I'm in Oakville, what highschool do you/did you go to?
im not exactly really sure, but i think it has to do with the direction the gears are cut...why is it that invert miata cams in our cars? Is it about the duration and/or the lift or the physical design?
But dont quote me on that. It could be just about anything.
But if you get a miata head, then i assume you would leave them where they are.
Bochek
http://www.mx-3.com/phpbb2/viewtopic.php?t=50988
Supposedly it's possible... I'm gonna go to the mazda dealership and order both head gaskets I think. That way I'll be able to compare them, just to make sure everything lines up before I blow too much money on a dohc head buildup. I'll buy one of the two head gaskets and probably pay some sort of handling fee for the other one. It'll be worth the extra $20 or so for the piece of mind that the swap will work.
- cjthor
No no no...its NOT possible. If you read...they say you can POSSIBLY swap out a 16 valve head for your 8 valve head. the DOHC head is wider, oil and water ports are different, distributor is different, just to name a few. Sorry!Boris wrote:http://www.mx-3.com/phpbb2/viewtopic.php?t=50988
Jarid Perry
71 Chevy C20 (tow rig!!)
2008 MINI Cooper Clubman S
