Fuel Pump Relay Question.
If the relay in our Gs's go bad, is there a way to bypass them so i dont have to pay 80 billion dollars to buy a new one ?
- hppwdn
You could just go to a local junkyard and get another or get one from someone on mx-3.com.
But yes, you can bypass the relay. It's just as easy to pick a new one up at the junkyard and not worry about having a hardwired fuel pump.
You could also get any generic relay and wire it in. I think a 30 Amp relay costs about $4.99 or something like that.
94 Mx-3 Precidia
ew @ dealership.. ive seen them for around 30 at autoparts stores
-hec
- PATDIESEL
You could do it a few ways.
1. use a spade terminal to plug into the slots where the sotck one pugs into the fuse box and run the wires to the new one. Cut a small hole in the side of the lid of the fuse box so that you can run the wire out without pinching it.
2. You could take the fuse box out and then pull the terminals out of the sockets of the plastic and harwire them to the new wires. Run the new wires out the bottom of the box and to the new relay.
I'd check all parts stores for a stock replacement first. It will be alot cheaper and easier.
As for exact wiring, the generic relay will have the wiring instructions and the stock realy will have a diagram on top of it if I'm not mistaken.
Check your "Fuel Injector" fuse in the engine bay first thing.
If thats ok, your best bet is to check for power at the BLACK / RED wire on the relay. If you got power, check at the fuel pump under the back seat.
If no power at those we can work backwards to find where the fauls is.
