Turbo Mainfold
Posted: April 25th, 2006, 12:41 pm
by ModMX3 - (Carmaster2005)
Hey everyone, New to the turbo stage! dose anyone know what kind of turbo this is ? iHi RHB5 off the ford probe works with the mx-6. will that mainfold fit on my 94 1.6 DOHC b6 ? even with modifing ? and if not will that turbo match up to the 88-89 323 gtx turbo mainfold ? if not for that what moding would you have to do to get that turbo to fit on my engine ? this would help alot ! thanks
Posted: April 25th, 2006, 9:32 pm
by Dom
its the first gen mx6/probegt turbo...manifold wont fit ur 1.6 as its for the mazda 2.2block as for the turbo fitting a 323 manifold im not sure, but its not much of a turbo...kinda small and upgrading isnt that easy as there arent to many ihi turbos readily available unless u buy new
Posted: April 26th, 2006, 3:51 am
Thanks man! I just found out for sure the turbo will match up with a 323 gtx mainfold :D now all i need is all the plumbing, feed lines , boost controller , and a few other things and im ready to boost yaaaaaa! :D
