Turbo Mainfold
ModMX3 - (Carmaster2005)
Turbo Mainfold
Hey everyone, New to the turbo stage! dose anyone know what kind of turbo this is ? iHi RHB5 off the ford probe works with the mx-6. will that mainfold fit on my 94 1.6 DOHC b6 ? even with modifing ? and if not will that turbo match up to the 88-89 323 gtx turbo mainfold ? if not for that what moding would you have to do to get that turbo to fit on my engine ? this would help alot ! thanks
Apexi Safc 2 ,Timex Boost-Temp-Oil Gauges, Stage 1 Performance clutch, 8.5 mm Magnacore plug Wires,2.5 inch exhaust, Cold Air Intake , Short Shifter , High temp rotors & Ceramic pads to slow it all down !
Thanks man! I just found out for sure the turbo will match up with a 323 gtx mainfold
now all i need is all the plumbing, feed lines , boost controller , and a few other things and im ready to boost yaaaaaa!
