HEI power tower
HEI power tower
I plan on doing the HEI disty conversion as a precaution and I've read over the posts on how it's done, but I have one question. The power tower that is drilled into the cap, is there some kind to metal in the top of the cap that the tower makes contact with so the spark will be distributed to the plugs. The pictures I've seen just show the tower sealed into the cap, but there has to be some kind of metal connection for the electrical current. Also is it worth the extra money to buy the blaster coil and/or the premade power cap from the probe site.
Owner of 7 different cars, 5 being convertibles. 1990 Miata is one of my summer fun cars. I enjoy that car so much, I thought owning a MX3 would be fun also. Drive with your top open or top down. See my car web site at http://www.cardomain.com/ride/816145
- Custommx3
- Site Administrator
If you open your cap and look inside it, you'll notice a strip thats raised, thats the metal stap you hav to drill into. Its molded in so you have to drill through the plastic. Id suggest use a drill bit the size of the scrw in the power tower, then using a countersink so the bolt is flush with the cap on the inside to prevent rubbing.
