Page 1 of 2
whats your ZE's 1/4 times???
Posted: April 22nd, 2006, 5:43 pm
by PWRD_BY_HKS
just to make sure those clocks hec and i raced on were off what should a ze clock on the 1/4 mile i crossed the line at about 95 mph i kept on getting 15s. Just if you'd be courtious enough to post your times yeah..... that would be cool.
Posted: April 22nd, 2006, 5:57 pm
by PWRD_BY_HKS
ill try using the kl31 ecu next time to see what happends im running the kl36
Posted: April 22nd, 2006, 7:30 pm
by Nd4SpdSe
15.454 @ 90.21Mph
Check signature for mods
(* mods are not installed)
Posted: April 23rd, 2006, 1:13 am
by Slammed6
PWRD_BY_HKS wrote:ill try using the kl31 ecu next time to see what happends im running the kl36
Thats not gonna make a difference....they are the same ECU
I never ran my car all motor at a track...so i wouldn't be able to say
Posted: April 23rd, 2006, 1:16 am
by Juans_93_MX3
15s seem to be popular with the ZE's
WTF?
I thought a MX3 with a ZE would be able to atleast get a mid/high 14. Thats of course, with minimal swap (stock clutch, exhaust, flywheel, ect)
Posted: April 23rd, 2006, 2:04 am
by PWRD_BY_HKS
What The F*** mann my last ze was so much faster and i ran it on slicks and a k8 ecu and my highest times were 14.9 my lowest was a 14.3 would that be it right there the ecu.......im gonna use my G-force drag radials i just got and see how it goes but to slip that much from a 14.3 to high 15s...... is that possible
Posted: April 23rd, 2006, 2:08 am
by hgallegos915
I say slap back the klze ecu in there, slap new tires, get the millenia throttle body because the k8 is smaller and that should give u some 14s. Also mx3 clutches are notorious for slipping at high rpms and us not even knowing (been researching a bit)
Posted: April 23rd, 2006, 2:13 am
by PWRD_BY_HKS
i know that millenia manifold will throw it down with extra ponies not too many but yeah... but then in again consider i ran the stock k8 manifold with the last engine ...... so throttle body?? tires??? or ecu????
Posted: April 23rd, 2006, 2:20 am
by hgallegos915
oh thats right i had forgotten hmm thats weird...
Posted: April 23rd, 2006, 9:32 am
by XxantwawnxX
14.2 98 miles an hour with De mani (DE tb) and gutted car. aftermarket exhaust and cold air.
Posted: April 23rd, 2006, 10:58 am
by babyblueMX3
ze minor mods, winter tires, 14.5 @ 95mph N/A
go check out the thread I made last year or the one before about the drag board. Many times and mod in there
Posted: April 23rd, 2006, 2:57 pm
by fowljesse
Also consider altitude and ambient heat. Try icing the IM between runs, and if you're really ambitious, you could take off your belts for a run & remove the battery. My car runs 98% better in Portland than it did in Houston.
Posted: April 23rd, 2006, 3:25 pm
by PWRD_BY_HKS
fowljesse wrote:Also consider altitude and ambient heat. Try icing the IM between runs, and if you're really ambitious, you could take off your belts for a run & remove the battery. My car runs 98% better in Portland than it did in Houston.
...........seat belts huh?
Posted: April 23rd, 2006, 3:30 pm
by babyblueMX3
I hope you're not serious
Posted: April 23rd, 2006, 3:34 pm
by relisys_3200
lol
