![Cool 8)](./images/smilies/icon_cool.gif)
whats your ZE's 1/4 times???
- PWRD_BY_HKS
just to make sure those clocks hec and i raced on were off what should a ze clock on the 1/4 mile i crossed the line at about 95 mph i kept on getting 15s. Just if you'd be courtious enough to post your times yeah..... that would be cool. ![Cool 8)](./images/smilies/icon_cool.gif)
jdmx-3 KID OF THE ![Image](http://img118.imageshack.us/img118/8885/3kidkn5.jpg)
VICTORIA RACING
ZE PERFORMANCE IN 915 TX
Kl01-ZE,Kl31 ecu, millenia manifold, ngk plugs, ngk wires, probe tranny/ and clutch (stock), VortecH FMU 12:1, Aeromotive AFPR, Tial .38mm Wastegate w/ 4lbs spring, Walboro 255 pump, AiResearch T4, 3" down pipe, GODSPEED manifold, Spearco Boost Gauges, BF Goodrich G-force drag radials.
14.8 1/4 mile all motor untimed on boost.
VICTORIA RACING
- PWRD_BY_HKS
ill try using the kl31 ecu next time to see what happends im running the kl36
VICTORIA RACING
VICTORIA RACING
15.454 @ 90.21Mph
Check signature for mods
(* mods are not installed)
15s seem to be popular with the ZE's
WTF?
I thought a MX3 with a ZE would be able to atleast get a mid/high 14. Thats of course, with minimal swap (stock clutch, exhaust, flywheel, ect)
WTF?
2008 Mazda 3
1993 MX3 GS
1993 MX3 GS
- PWRD_BY_HKS
What The F*** mann my last ze was so much faster and i ran it on slicks and a k8 ecu and my highest times were 14.9 my lowest was a 14.3 would that be it right there the ecu.......im gonna use my G-force drag radials i just got and see how it goes but to slip that much from a 14.3 to high 15s...... is that possible
VICTORIA RACING
VICTORIA RACING
I say slap back the klze ecu in there, slap new tires, get the millenia throttle body because the k8 is smaller and that should give u some 14s. Also mx3 clutches are notorious for slipping at high rpms and us not even knowing (been researching a bit)
-hec
- PWRD_BY_HKS
i know that millenia manifold will throw it down with extra ponies not too many but yeah... but then in again consider i ran the stock k8 manifold with the last engine ...... so throttle body?? tires??? or ecu????
VICTORIA RACING
VICTORIA RACING
oh thats right i had forgotten hmm thats weird...
-hec
- XxantwawnxX
14.2 98 miles an hour with De mani (DE tb) and gutted car. aftermarket exhaust and cold air.
- babyblueMX3
ze minor mods, winter tires, 14.5 @ 95mph N/A
go check out the thread I made last year or the one before about the drag board. Many times and mod in there
RIP 400whp ZE-T MX-3
- fowljesse
Also consider altitude and ambient heat. Try icing the IM between runs, and if you're really ambitious, you could take off your belts for a run & remove the battery. My car runs 98% better in Portland than it did in Houston.
- PWRD_BY_HKS
...........seat belts huh?fowljesse wrote:Also consider altitude and ambient heat. Try icing the IM between runs, and if you're really ambitious, you could take off your belts for a run & remove the battery. My car runs 98% better in Portland than it did in Houston.
VICTORIA RACING
VICTORIA RACING
- babyblueMX3
- relisys_3200
