Page 1 of 2
finally she broke..
Posted: March 28th, 2006, 11:00 pm
by MAZDASPEEDMX-3
ok well my fears finally became a reality on sunday night. i was on my way back to my moms house in ocean city md, coming from virginia, and i got to the toll booth for the bay bridge, and well as always i love to fly outa the toll booths the only diff is i got new tires(my old ones were bald and dryroted). so i take off just burnin up 1st gear take her to 6500 smack 2nd mash the gas and all i hear is boom wapwapwapwapwapwap...imediatly i knew what had happend.so i coast over and get out to look at the damages and sure enough i snaped the passenger cv shaft clean in two just as i thought. so yea had to get towed all the rest of the way home(which was a pretty penny). so yea now shes in the shop gettin fixed.
so now im a lil scared. i was planin on takin my car to the strip this sunday and now im wondering if im gonna be left stranded at the track bc of the same problem after shes fixed. have any of you guys had your cv shafts break with the ze swap(the only things ive done to it is upgraded clutch and home made cai. so do ya think maybe need to maybe hold off on the track..tell me what ya think...thanks[/img]
Posted: March 28th, 2006, 11:15 pm
by fieromx3
many ppl have snapped them with a ZE swap. when u get it fixed i think ur ok to go to the drag strip just do not rev it up high and dump the clutch just ease into it slipping the clutch on take of so u dont put a sudden shock on them and snap them.
Posted: March 28th, 2006, 11:21 pm
by Rick Johnson
The new axle should hold up for a while, unless your getting massive wheelhop then stop launching as hard while at the track.
Posted: March 28th, 2006, 11:27 pm
by MAZDASPEEDMX-3
yea see what suprised me was that this time i had zero wheel hop. and when i launch i dont go very high at all just bc of traction problems. like generally about 2500-2750. but yea im prolly gonna try and take it easy at the track and work my way up, and hopefully nothin will happen.
![Driver :driver:](./images/smilies/driver.gif)
Posted: March 29th, 2006, 2:55 am
by Slammed6
I never launch my car and i never get wheel hop and i snapped an axle that was brand new in 1 shift.
I always just slip the clutch at 1000 RPMS and then open it up and when i slam 2nd i snapped it. Done it several times...and this is without the nitrous.
Posted: March 29th, 2006, 7:36 am
by mxmaz
Do not buy a reman. axle, buy a brand new one and you will be fine.
Posted: March 29th, 2006, 12:19 pm
by Slammed6
thats the thing, where i snap the axle it doesn't matter if it was a brand new one or a remanufactured one. Its a solid piece of steel, so how u explain that?
Posted: March 29th, 2006, 12:54 pm
by precidian
Usually if an item breaks, it tends to be at a weak point. This would indicate some sort of metal fatigue. Either due to stress, imperfection or other failure.
Posted: March 29th, 2006, 1:09 pm
by mxmaz
Slammed6 wrote:thats the thing, where i snap the axle it doesn't matter if it was a brand new one or a remanufactured one. Its a solid piece of steel, so how u explain that?
I dont know how to explain it but reman's are notorious for snapping like that. Whenever somebody snaps one it is usually a reman. unless it a 15 year old stock one.
Posted: March 29th, 2006, 1:58 pm
by PATDIESEL
I've never heard of anyone snapping an OEM axle. You should see the difference in the OEM and a remann. ITwill scare you that you bought the remann. However, the problem is that Mazda does not have any more axles for the Mx-3 any more. So remann is probably your only choice unless you want to upgrade the axles for the high HP expensive units.
You should be fine if you use a good remanned axle and slip the clutch not dropping it. It is much better to wear the clutch by slipping overdropping it which will break the trans casing.
Posted: March 29th, 2006, 2:48 pm
by Mnemonic
i'm running on 2 remmans from napa and havent had any problem beside the boots rip open, i can launch at high rpms adn spin tires, axles are pritty strong.
I know a few guys who went and got autozones axles said they've snapped a few ::shrugs::
Posted: March 29th, 2006, 3:03 pm
by yvan
booty,,booty.. autozone..napa..checkher, they'll all pertty much the same axle, just have their store name label on it. check the part # and compare. got raman axle form napa, n they clunk..but still holding ok, havn't really abuse her yet, can't go wrong with oem man
Posted: March 29th, 2006, 3:21 pm
by lakersfan1
If it's clunking you should take it back as soon as you have a chance to do the swap again. My first reman was like that .... worse than the one I turned in even. But the second one I got works really well so far, and I've done road racing on it. But I usually don't do hard 1st gear launches. That's more a drag strip thing, which I don't do.
Posted: March 29th, 2006, 7:04 pm
by MAZDASPEEDMX-3
yea i bought a axle from autozone and its held for a while, it was my oem axle that broke
see thats what made me think my reman wasnt to bad i compaired them and they were pretty much the same width..and yea i really dont wanna buy high hp ones even though in the long run it would prolly be better. i was wondering though if anybody on here has had any experience with the upgrade axles from corksport? if so do ya like em?
Posted: March 30th, 2006, 2:40 am
by MX3 GSR for dummies
I have been scared to run the 1/4 mile for the same exact reason but ....your dumping at 2000rpm? I know the Ze has torque especially since I have a straight neck but when I race at my circuit events which are on normal average street like lots, I dump at 4000. I do this by keeping it steady at 4 and then when I launch I make an effort to keep the throttle the same until it hooks and then I just aggressively but gradually work up to full throttle as quick as possible. It will take some practice but once you get it, It just consistantly accellerates and gives an awsome launch. I even notice the vris tend to kick in quicker apposed to dropping in the 2000 range. Kinda like when you are cruising in 4th and you drop it to 2nd...compared to cruising and then flooring it. I at least notice the different re-action by the vris.
