My strut mounting plate came loose from the strut
Posted: March 26th, 2006, 8:05 pm
by MOSES
Im supposing this is dangerous so I need to get it fixed/replaced asap,
is there a way to repair this, its the rubber mounting that fits up in the metel bracket, theres no bolts broken, just the rubber is pulled away from the rest.
Posted: March 26th, 2006, 9:44 pm
by 1992blazeredgs
You can buy a new strut mount for like $50 bucks. That is pretty cheap fix. So i wouldnt worry about trying to fix the one you have.
Nate
Posted: March 31st, 2006, 11:21 pm
by reprobation
I was told that the rubber area around it was more of a piece that just minimized vibration thoughout the strut mount... I believe the rubber piece actually sit on top of the mount and under the area where the strut actually bolts up to the chassis of the car...
I could be wrong.. but.
the same rubber piece your worried about is worn out in my car.. the rubber is not completely torn away.. but it is torn.. I haven't had any problems and i've been rolling around on this for about a year now ..
-Chris
Posted: April 2nd, 2006, 6:19 pm
by MOSES
well the problem is, when i jacked the car up, the strut assembly (spring, strut and wheel) jsut sat there as the car went up, the plate with the 4 bolts stayed in the strut housing(wheel well) and the rest came done.
confusing? lol lol
when i took the plate of from the car, it had a little bit of that rubber on it and i could fit it back onto the strut, but ofcourse it needs to be made back on to it again.
Posted: April 2nd, 2006, 6:34 pm
by mitmaks
id replace with solid mounts
Posted: April 2nd, 2006, 7:09 pm
by hgallegos915
yup yup mine have been like that for 4 monhts, i havent had time to fix it, its an annoyance..the noise
ill fix it in a few weeks. They are cheap like 50 dllrs from tirerack.com
Posted: April 3rd, 2006, 10:17 am
by lakersfan1
I found the front ones at my local Pep Boys for $35 with the bearing.
Posted: April 5th, 2006, 8:37 pm
by hgallegos915
WOW thats cheap o.0 got the part number? i will get one this weekend.
