B6 distributor to BP
xmaster19
Post by xmaster19 »
Ok, now I'd like to know if a B6 (94 1.6DOHC) distributor would fit a 91 BP DOHC. I only want to know if it will bolt up, and work. I know the wiring is different, I'm taking care of that part. I only want to know if it will bolt up. Thanks.
92 MX-3 RS RIP
94 MX-3 RS Black
Project car, hybrid B5-ZET build-up.
xmaster19
Post by xmaster19 »
I found my own answer, the 1.6 DOHC distributor WILL bolt to a BP engine.
92 MX-3 RS RIP
94 MX-3 RS Black
Domnknpimp
Post by Domnknpimp »
you HAVE to use your original 1.6 dohc distributor, if not, you will have to re wire everything.
