Help please! Really imp. Coil over stuff
Ok. I can get ground control coil overs from a 93 v6 se mx-3. the only catch is it attatched to the stock shock and strut and i have to trade my stock spring/shock/strut for it. Can i put the whole part from the 93 v6 into my 94 1.6 dohc? Will it pop right in? Please help, i need to know b4 the deal passes by! thanks, mike
Re: Help please! Really imp. Coil over stuff
please HELP......... I need help
Hey Mikey, YES you can just pop them right in...Manny
Yeah you can put them. but the problem is that if there are of a v6 into a 4cyl, there different preasure so you car won't low that much because is a lighter engine and each srtut comes with a specification for each engine; but they should fit at least.
