[WTB] GS fuel pressure regulator VACUM sensor
Ok i have been looking for MONTHS yes months..not at the junk yard no where... its just a stupid sensor that looks like a vris solenoid and i cant find it anywhere. My MPG is horrible :S goes to the fuel pressure regulator.
-hec
- hppwdn
That solenoid is only for cold starts. You don't really need it (at least living in South Florida I don't). Just run the vac straight off of the IM to the FPR.
But if you are set on getting one you can use a VRIS solenoid there. They are the exact same part.
- jschrauwen
If you're referring to the PRC solenoid. The unit that normally mounts to the side of the oem airbox, has a 2 wire connector that traces back to the VAF wire loom and has a vaccum port that is hooked to the FPR, than this unit is not for cold weather/cold engine starts. It's actually for the opposite. I believe taking it's temp data info from the temp sensor within the VAF, it will electically seal the vaccum line for 120 seconds to the FPR during HOT engine re-starts so that it will richen the mixture. Hector, I guess it would be a hit miss thing to find an MX in the junkyard that still had it's original oem airbox which would certainly indicate that the PRC solenoid is there also. g/l
John
John
