running too rich..
running too rich..
hi my car is running too rich or sumthin datz wat da mechanic told me...i got a 94 kl-de swap,kl-02 vaf,n kl-57 ecu...
da mechanic told ya your kar is running 2 rich? man i wish i was rich too
a good mech should also tell you why its running rich, ther alot-o stuff that can caz it to run rich. sensor.sensor..timing..timing. and ect. you know where this is going right>?
i would start off with regular tune up- plugs,wire, cap n rotor, check timing, and that should put you in the ball park.
93' blue mx-3, klze curve neck, kl36ecu, all the upgrade possible/out turbo.
- jschrauwen
http://www.mx-3.com/phpbb2/viewtopic.ph ... light=rich
