I need a flywheel as soon as possible. I need to know if there are any interchangable flywheels for the K8. My flywheel is unrepairable...I tore it up pretty bad...I also need front and rear transmission mounts.
~Jay
Flywheels
- JYOUNYA1
Flywheels
93 MX-3 GS 1.8 Liter V6 Teal Mods: Pace (Maker) Setter Custom Catback/ Phantom Auto Meters: Voltage/ Water temp, Air/Fuel (in which not one gauge except voltage works) / Custom piece of s*** intake / 17" RacingHart Z5000 wrap in Khumos that are dry rotten / Altezza Tail lamps/ Custom Black interior (still in the works)/reverse indiglo gauges/ Push Button Starter/ Viper alarm with Proximity sensor/ Brembo slotted and dimpled rotors/ rear hatch shade/ Pioneer Premier DEH-840MP, ,2 custome fitted 6"inch pioneer door speakers, 1 Pioneer Premier 200 watt amp
- vozaday2000
but the fidanza is by far worth it. it is freakin awesome
