Turbo B6 dohc, look inside.
Posted: February 27th, 2006, 9:05 am
by nos92mx3
what injectors are you guys using and what (if any) mods needed to be done to run them?
Also where is the coolant temperature sensor located, on the b6t its located under the intake manifold...
Posted: March 7th, 2006, 4:21 pm
by facko
i have bp injectors in mine cuz those were the biggest (as far as i found) that i could run w/o adding some sorta electronic fuel management system. i only run like 8lbs of boost and they work fine.
Posted: March 8th, 2006, 7:35 pm
by nos92mx3
Anyone know if the rx7 460's(?) will fit?
Posted: March 8th, 2006, 8:10 pm
by Joey's mx
yes they do! i am running those, also BUGS is running those!! If you get 90 and up there is no mods to be done but the older ones you will need the plugs!! Also some of the older ones are low impedance so you would need a resitor box to run them!!
Posted: March 9th, 2006, 10:28 am
by nos92mx3
Thanks thats good to know.
