Turbo B6 dohc, look inside.
nos92mx3
Post by nos92mx3 »
what injectors are you guys using and what (if any) mods needed to be done to run them?
Also where is the coolant temperature sensor located, on the b6t its located under the intake manifold...
92' Rs-t b6t/De - RIP
93' Rs-t BPT - Sold
03' WRB wrx Wagon - Current
facko
Post by facko »
i have bp injectors in mine cuz those were the biggest (as far as i found) that i could run w/o adding some sorta electronic fuel management system. i only run like 8lbs of boost and they work fine.
BP swap -- Pacesetter Header -- Custom CAI -- Custom 2.5 Exhaust w/ a Thrush Glasspack and 40 Series Flowmaster -- SPEC Stage 2 Clutch Kit
nos92mx3
Post by nos92mx3 »
Anyone know if the rx7 460's(?) will fit?
93' Rs-t BPT - Sold
Joey's mx
Post by Joey's mx »
yes they do! i am running those, also BUGS is running those!! If you get 90 and up there is no mods to be done but the older ones you will need the plugs!! Also some of the older ones are low impedance so you would need a resitor box to run them!!
nos92mx3
Post by nos92mx3 »
Thanks thats good to know.
93' Rs-t BPT - Sold
Return to “Forced Induction”
