Good place to run coolant lines?
Joey's mx
Post by Joey's mx »
Would it be a good thing to run the coolant lines where they go to the throttle body?? I bypassed those line 2 years ago so the fittings on the pipes are unused!! Would that be a good source for coolant to and from the turbo??
max kl
Post by max kl »
yea they would work ok for turbo cooling
the orginal purpose of the lines is to heat the t.b. to stop it from freeing and sticking open so on a turbo car its problly not gona freeze unless you have a realy good intercooler and realy cold weather
JUDGE ME ALL YOU WANT
93 gs, klde swap, kl trans, strait 2.5'' ehaust, euro front bumper, cold air intake, hei ign ,50 shot &
9.60s n the 8th mile so far 8.50s sprayn now
150 shot
XxantwawnxX
Post by XxantwawnxX »
You will have weird Idle on cold days un till the manifold warms up the TB.
XxantwawnxX
U can probably run it from the block to the turbo back to the TB and back to the EGR (or which ever way it flows) that way u can supply the turbo and still supply the TB
Return to “Forced Induction”
