darn it help
darn it help
ok well actually my problem isnt that bad. i just got my car back and the alternator, belt and throttle posistion pin is fixed. before it went in oil got all over my plugs. (cheap set) and now when i stop the rpms come down and get real jumpy just like it did before it died but the car still runs good when moving and the light dont dim i was thinkin like o2 sensor or maybe the plugs r messed up. anywayz i really appreciate the help thanks. p.s valve cover gasket done also explaining oil in plugs.
[Admin:watch the language!]
intake, exhaust, fully slammed, 16' konig theorys, plugs, wires, the usual
It sounds like you're having the same problem alot of people are having, myself included. I don't know how to fix it, though (think some people said somethin about vacuum hose). It's wierd cause one day mine just stopped doin that. It was horrible and just got worse, like I would stop at a stop sign or light, and it would drop down then jump up, then it would die and it took like a minute to start it back up.
Is this what you're talkin about?
some break cleaner and a que tip.suckinboost wrote:quick question what should i use to clean the throttle body? i heard pb blaster
take off the intake tube, and clean around and behind the butterfly valve, engine will run like s--- for 5 mins after, just let it idle for a few mins and she'll be good to go.
Bochek
- Tunes67
Check the 4cyl FAQ.. There is a write up with pics showing how to clean your throttle body and how to adjust your TPS sensor.
Tunes67
Tunes67
"So long.. and thanks for all the fish!" "Momma says VW Bugs are the devil" "This one time at band camp.. I stuck a flute in my Throttle Body" ![Wink ;)](./images/smilies/icon_wink.gif)
