Boost vs. Emissions
Boost vs. Emissions
Just wondering if any of you guys with boosted motors are having any problems passing the emissions test??
- mr1in6billion
projectmx
easy way to pass emisions is set up some kind of blower system into the exhaust, it will do wonders for emissions... i've seen some ford v8 engines that have that stock
ProjectMx
My BP and AWD build thread
Cardomain
93 Escort GT daily driving
Cardomain
- Josh
all you have to do to pass is either swap in some small injectors and cut boost way back, and install a normal restrictive kat, and you should be fine.
- mr1in6billion
What do you think their going to say when they see your car =bJosh wrote:all you have to do to pass is either swap in some small injectors and cut boost way back, and install a normal restrictive kat, and you should be fine.
Not sure what the rest of the country is like, but out here in Cali we have to undergo a visual inspection as well as the sniff test (which is supposedly also compared with some sheet to make sure the results match the type of car.).
- XxantwawnxX
wherei live we dont have emissions testing...
- babyblueMX3
here too heheheXxantwawnxX wrote:wherei live we dont have emissions testing...
RIP 400whp ZE-T MX-3
Mnemonic
Emissions what's that? We have them but not in every county, just make sure you have a family member that lives in one of those counties that doesnt have themXxantwawnxX wrote:wherei live we dont have emissions testing...
20 dollars? I think the going rate to pay to pass is 100 now
01 Lexus Is300 (LS2 Project)
93 Mx3 SE 2.5 KLZE (sold it)
