Modifications for running boost on ZE
Tommy D
Post by Tommy D »
I am going to Turbo my ZE with the full Kit here.
I intend to do the MS at a later date but i intend to run 6psi on my KL31 ECU for a few months whilst i save up. To do this as far as i am aware i will need nothing except for Bigger Injectors, Millennia S 280cc or similar. Does anyone know where i can get these? or will my KL31 Injectors do for the mean time (dont want to run lean!) I have a Xedos 9 Inlet coming with KL68 TB, will this have S injectors or if not where can i get some from. I dont want to do too much at one go.
I will get it mapped at a later date so i can run the max reccomended 10psi and get rid of thet AFM/VAF so all is at final spec. I just want Boost asap!
Will this be a sensible approach or have i missed anything that will help? Its Advertised as a bolt on kit so i presume thats just it...? Thanks :D
babyblueMX3
Post by babyblueMX3 »
yes it is a bolt on kit but you don't go nothing that involves fuel, you'll need a rise rate fuel pressure regulator (FMU) and a fuel pressure regulator (to use with the 280cc injectors)
you can fin some on car-parts.com but I don't they ship overseas
RIP 400whp ZE-T MX-3
Tommy D
Post by Tommy D »
I have a FPR from Ebay, it has a guage on the front and its chrome. Do i need a seperate RR-FPR? Do i have the wrong one? Any links to the one i need?
babyblueMX3
you need a fuel pressure regualtor that rises with boost or else it's useless.
look for FMU when searching
Tommy D
Post by Tommy D »
Right so then for converting my MX ZE to a turbo i need
The Complete kit from Oscar...
To Remove Boomerang shaped x-Member
To reweld the Engine Cradle x-member
To fit a RR-FPR
Fit my Eunos 800 IM, fit brown KJ 310cc injectors
Will that be ok for a big power increase without ECU, ie 250+bhp?
Do i need to get a MS2 done too? I will do MS2 eventually but it is so complicated if your not confident, and could get expensive! How long should a decent Tuning shop take to fit a MS2 from the box and set it up for a ZE Turbo, or can i plug it up and let pros do it in a matter of a few hrs.
Thanks for reading, i know im asking similar questions alot but its because a need concrete answers..........Tom
Tommy D
Post by Tommy D »
This is the Regulator i currently have, but for mx3
(http://www.cosmo-racing.com/sale/fuelr/fuel.jpg)
and this is the one i think i need or do i need both??
(http://www.trendgear.net/auto/FMU_s_OBX.jpg)
Am i correct? The FMU should save me having to f around with ECU and run 310cc KJ inj ok, Cheers?
Return to “Forced Induction”
