idle go crazy...
tk2269
idle go crazy...
Post by tk2269 »
hi ever since i got da DE swap,everytime when im holding down da clutch da idles keep jumping up and down,and sumtimes even when imnot holdin down da clutch it does it too....I brought it to every mechanic out dere n dey cant seem to figure out wats rong wit it...
XxantwawnxX
Post by XxantwawnxX »
How much range is the jumpage in idle? Does it otherwise drive normally?
tk2269
Post by tk2269 »
i jumps from 500rpm to 2000rpm,itt keeps jumpin until i let da clutch go,den it will stop,but sumetimes even tho i let da clutch go it will still do dat...besides dat it drives normal...itz juz annoying because of da sound...
jschrauwen
Re: idle go crazy...
Post by jschrauwen »
tk2269 wrote: I brought it to every mechanic out dere n dey cant seem to figure out wats rong wit it...
And these must also be one of the mechanics that installed the DE? Damage repair after poor install.
Try looking for a vaccum leak or a crack in your intake tube to the TB. You gave minimal info other than eratic idle. Had you done a search on that topic your answers are all there, many times over. Try "surging", "idle", "eratic", and "fluctuating" as key words in your search parameters. It's all there.
Custommx3
Site Administrator
Post by Custommx3 »
tk2269 wrote:i jumps from 500rpm to 2000rpm,itt keeps jumpin until i let da clutch go,den it will stop,but sumetimes even tho i let da clutch go it will still do dat...besides dat it drives normal...itz juz annoying because of da sound...
U know, I bets it beez da Throtta pusition sensa settins, read da faks. Derz a how-to own it in der.
jschrauwen
U nose, yews cood be rite. ah ah ah, hay, dats mi teepas owtoo ... ah ah ah
Tunes67
Post by Tunes67 »
LMAO :laugh: :laugh:
XxantwawnxX
Asumeing they did not bypass the throttlebody coolant lines. Id check for vacum leaks, and re set the TPS as these others have said.
Drewation
Post by Drewation »
usualy that happends to me when i try and drive hard on my car and the engine is noy at its regular tempature and still climbing or when the coolant was dry. it jumps between 1000-1500 rpms once i push in the clutch to neutral.
*new* 1995 Blaze Red MX-3 GS
http://www.cardomain.com/id/drewationmx3
jschrauwen
Drewation wrote:usualy that happends to me when i try and drive hard on my car and the engine is noy at its regular tempature and still climbing or when the coolant was dry. it jumps between 1000-1500 rpms once i push in the clutch to neutral.
Sounds like you've got major problems too. Coolant went dry? - :shock:
jbruynson
Post by jbruynson »
mines like that too, coolant is always empty. Filled it up, next day its gone. Took it in, they pressure tested and said no leaks...
Now I just dump some coolant in the rad every once and a while and hope for the best. I get erratic idle when its pretty much empty, thats about it.
Drewation
Post by Drewation »
that was before when my water pump went nothing major happend luckily since i regulary check my heat guage, it never did get to the point of over heating luckily
Drewation
Post by Drewation »
ive now found that if you ride the clutch to about your ideling rpms it wont do that first jump from gear to neatral and wont continuie with any others
max kl
Post by max kl »
it sounds like ur base idle is set to high. it is normal for the idle to go up slightly when u push in the clutch and shift into 1st . if your base idle is to high the engine will surge anytime the ecm raises the rpm for anything. like p/s a/c
or engage the clutch adj. tps and base idle speed should fix
JUDGE ME ALL YOU WANT
93 gs, klde swap, kl trans, strait 2.5'' ehaust, euro front bumper, cold air intake, hei ign ,50 shot &
9.60s n the 8th mile so far 8.50s sprayn now
150 shot
MOSES
Post by MOSES »
maybe you guys should try editing this in word perfect with spell check, then post it onto here, lol lol
but dont try putting these words through the thesaurus, your computers will crash. lol lol
I've been so unsatisfied with my car since I joined mx3.com.
Seeing all the body kits, rims and engine swaps makes me want to spend all my student loans on my car.
