alright everyone, I've look, and I havn't found anything as particluar as I need this to be.
this will be my first engine replacement.
I need to take the engine out of my mx3 which is a 1.6L.. fairly simply.. i think. However, the engine im getting, is also a 1.6L and it's just a replacement for the one i've got now. I need to put it in, now my wiring and everything is still excellent from my old engine.. so do I just take the wiring off the engine itself, leave it connected to everything else, and just replace the block and reconnect the wiring?
if someone could give me a completely detailed info sesson or link to it, that would be perfect.. all I've found on here is complete swaps.. I guess im only really doing half a swap lol
thanks, and be patient if it is on here somewhere and i've missed it, although I couldn't have!!
Craig!
New Engine
- MX3driver
- BANNED Member
New Engine
Ive been banned for moronic childish behavior.
- Shades
It's just unplug, and then plug and play... no extra stuff is needed.
If you're gonna change the timing belt, which you should and various other things you should change, do it while the engine is out.
![Image](http://i491.photobucket.com/albums/rr275/Spudsicles/BannerFx.jpg)
"Do it ONCE, do it RIGHT!"
Werd to that. Nothing more a pain in the a-- than changing a timing belt while motor is still in the car. Ok..maybe a few things but not many.Shades wrote:It's just unplug, and then plug and play... no extra stuff is needed.
