burning rubber smell
when I go from an idling position to accelerating i smell burning rubber. Any ideas? Clutch perhaps? how much does it cost to fix a clutch in canadian currency?
reaper of souls
reaper of souls
well if i were you i'd get that checked, because the more i drove the worst the smell got then all of a sudden my engine would overheat now my car doesnt even work anymore. so yeah, get that checked, i'd suggest u don't even drive ur car until u know what the problem is.rusty wrote:are you sure it's rubber not oil, cause in my car you can smell burnt oil after you accelerate from a stop. but the exhaust isn't blue like it's burning oil. Don't know where the smell is coming from
Darcy
I actually have the same problem. Smell the burnt rubber really bad, especially when I crank up the heat.
Coincidentally as the last post mentions, I recently had my header exhaust gasket replaced and I have a feeling it was right after that was when I started smelling the burned rubber smell.
Did you find out what the problem was?
96 X-90 4x4, 16v custom ram air intake lockers front and rear with 5.83 ring and pinion.
