Weird starting problem after DE swap
mx32nerDOTcom
Post by mx32nerDOTcom »
I have to hold my key in the crank position for like....8-20 seconds sometimes to get my car to start...Im not really sure what would cause it, once it starts, it won't idle, i thought maybe the idle was too low, would that cause it not starting right away? any help is appreciated
1992 Mazda MX-3 GS 5 Spd <i>*In Progress*</i> 2.5L V6 SWAP IN PROGRESS NOW
1993 Mazda MX-3 GS/SE 5 Spd <i>*Project 2.5T*</i>
lakersfan1
Post by lakersfan1 »
Two most common problems immediately after an engine swap:
1) Not enough grounds from the block to the chassis/battery.
2) Open/unused vacuum ports on the intake manifold.
In your case, I'd look for any vacuum nipples on the intake that aren't hooked up.
