can an intercooler be too big??
Can you run as big of a intercooler as you want, or does it have to be a certain size for certain power ranges?? Can an intercooler be to big for the setup??
osargeant
Yes it can be, the same way a turbo can be too big for a specific engine. Choosing an Intercooler should take into account your intended boost levels, flow/size of turbo to be used, engine size etc. It is not just a matter of finding the biggest IC that can fit and sticking it on.
JSpec Turbo MX3 (1.6 DOHC)
http://www.cardomain.com/memberpage/310985
Port and Polished Head, Ported Intake Manifold, Valve Job, GTX Manifold, Hybrid Turbo, Cone Filter, 2.5" Exhaust, 2.5" Downpipe, ACT Street Clutch, Lightened Flywheel, MSD 6A Ignition, Boost Retard and SS Coil, Magnecor Plug Wires, Denso Iridium Plugs, UR Lightened Pulley, Spearco FMIC, Turbo XS BOV & MBC, BEGI RRFPR, Supra Injectors, Walbro 255 Fuel Pump, Autometer Gauges, Pivot Shift Light
- relisys_3200
http://www.amazon.com/gp/product/083760 ... e&n=283155
buy this book, you will learn almost everything you'd like to know
Brandon
1992 MX-3 GS-ZE
1992 MX-3 GS-ZE
Juans_93_MX3
Isnt there a way to download these books?relisys_3200 wrote:http://www.amazon.com/gp/product/083760 ... e&n=283155
Is there by any chance a Super Charger Max Boost book?
Would you guys recommend those Maximum Boost books for people that are doing a S/C instead?
2008 Mazda 3
1993 MX3 GS
1993 MX3 GS
- PATDIESEL
SC is the same basic principals. You could use about half the info in Maximum Boost for a SC application. Tword the end of the book Corky Bell starts getting really specific about turbos, but the rest is general physics and math that would help for either type of boost.
- relisys_3200
Or you can just get this book by Corky Bell that is all superchargers
Brandon
1992 MX-3 GS-ZE
1992 MX-3 GS-ZE
- Franko
Its a very good book but since it is a couple of years old there are a few things that it does not touch on. I think it was made in like 1997 so theres a few things that arent in there.
