I know wot your gonna say, "blown head gasket."
But I've noticed other people's cars start up OK after overheating, even with serious head gasket problems.
I checked the spark plugs, they are black and burned out, any chance replacing them will at least get it started for now, or am I not gonna be that lucky?
overheated, cut out... now won't start. help please!
- Josh
chances are your definatly not that lucky. if it wont start at all its the head gasket for sure. it happens to the best of us.
- steelcity3
- Josh
iv blown two head gaskets due to bad milling and over heating, and neither time did water ever apear in the oil or oil in the water. so it doesent always happen. but normally it a definate signsteelcity3 wrote:did you check water for oil or oil for water? that is a sign of a blown head. Did it blow white smoke?
hmmmm thats odd...did the engine seize ? i had that happen on a buick when it overheated..4 cyl 2.0 :(also could be cracked block and gasket.. pleasenever run these cars hot
its crusial to turn them oiff as soon as it reaches the H and have it towed its cheaper.. (unless you live in the middle of nowhere like me) usually the fans fail anf this happens :/ i hope it all goes wll for you man.
-hec
