please help, engine wont start
arth91
Post by arth91 »
hey, we just finished doin the timing belt and the auto-tensioner was broken but we replaced everything. anyways we put on the timing belt and the car started. sounded great too. so we went on putting everything back on and once we finished the car wouldnt start. the crank does turn and there is spark in the plugs. it sounds like it is really close to starting but then the engine light and the oil light turns on. the oil seems fine and i would almost think the problem is electrical or sumthin simple and im an idiot, anyways please help! oh and i dunno if this helps or not but we need to fill the power steering fluid, wats the fastest way of doing so?
thanks again
ac
oh and i cant get the engine light to give me the codes?
'96 precidia gs 1.8l, no a/c
arth91
Post by arth91 »
actually when im tryin to start it the oil light is not on but it is when its just resting in the on position not starting. the engine light is on after and during starting but when i try to read the codes by connecting GRD and TEN wit a clip the light just stays solid. you bridge while tis off, then move key to on, then watch.... right? it just stays solid on mine doesnt turn off ever or anythin
