Gains from Protege Intake Manifold?
Mazda_Power
Post by Mazda_Power »
Check out this 2G Protege manifold... I noticed one while changing oil. I wonder if they flow better. Does anyone know?
'92 Festiva L powered by a 1.8L SOHC Protege motor - For Sale
Post by Josh »
i was looking at that a while back. they seem to be about the same size and length runners, just not cast. but one way it would benifit is for heat. i tink it would stay alot cooler than the cast one found on the MX
freyguy_412
Post by freyguy_412 »
Hey, I tend to suck with engine identification.... is that a B6? What year Protege is it out of cause if that intake manifold would fit I'll be down at my junkyard this weekend!!! :wink:
It might be slow, but it's not a civic!
atlantamx3
Post by atlantamx3 »
It looks like a--. I dont care what kind of Gains you get- that would not go in MY car, EVER!
~Perry
Please visit
http://www.mx3-atlanta.com
Mazda_Power
It looks bad?
I didn't know that we based performance on looks? :wink:
The engine is actually a B5 (1.5L DOHC) I doubt there would be much for gains since the engine displaces less, but stranger things have happened.
Post by Josh »
the same mani is found on a 1.6 also. it does look like a--, or a toyota mani. but it would stay cooler than the cast mani.
freyguy_412
so this thing would fit on my b6de? looks like i'm going hunting this weekend!!
i think it would be cooler and flow a lot better with out the vics chamber tumbling the air around... at least it doesn't look like it has vics anyway...
would anyone know if I'm going to need the protege tb too or will my stock one work?
BuGS
Post by BuGS »
When they took the 2g top and mated it to the 1st gen bottom they made a little. But not enouhg to make it worth it.
Shades
Post by Shades »
Is that even gonna match up to a B6 head?...
"Do it ONCE, do it RIGHT!"
Mazda_Power
It should since it's found on the B5 and B6 DOHC. I think I'll try one out on my Festy project.
Mazda_Power
Then I found this... Is this a B6 DOHC w/out VICS? Does it have coil packs???!!!???! No disty. SWEET!
Mazda_Power
Or did someone steal it?!
JZProwler
Post by JZProwler »
that first one mentioned is actually the Z5, and the manifold does not match up to the B6 head..the ports are different shapes, as you can see in this link if you scroll down about 3/4 through the thread. just thought i'd help =)
freyguy_412
What about those of us with a 1.6 and a head with a B5 something stamped on 'em lol... ? Would that work?
Mazda_Power
Just like mine... :D
