Horrible knocking noise under acceleration
My 1.6 dohc 97 mx3 has a very ugly and anoying and horrible knocking noise that happens when I accelerate:
1) Does not happens when car is idle...
2) Does happens in a slow speed
3) Does happens when I "force" the engine (when I step hard in 2nd and 3rd)
4) Does happens any time, cold or hot, no matter the climate
- ovendenk
is it proportional to the speed of the engine or the wheels? ie. when you change gears and the engine speed drops, does it become less noticeable? this will help to determine if it's an internal problem or not.
kevin (aka The Oven)
93 mx-3 GS KL-ZE with KL31 cams and properly chipped ecu
All mods are on my website: http://ca.geocities.com/ovendenk
MX-3.com Worklog: http://www.mx-3.com/phpbb2/viewtopic.php?t=48462
The sound goes away as speed increases...
It only happens (for example) when I'm in 3rd and I need to slow down, I change to 2nd gear and step hard I can hear the knocking sounds...
But it goes away as soon I change to 3rd and speed is increased.
- azazel95
Maybe axles or your tranny getting ready to go?fir3 wrote:is it proportional to the speed of the engine or the wheels?
BTW, if you're slowing down, why do you drop a gear and slam the gas? That would just cause an increase in speed.
- Thunderstorm
Re: Horrible knocking noise under acceleration
Hi fir3!fir3 wrote:My 1.6 dohc 97 mx3 has a very ugly and anoying and horrible knocking noise that happens when I accelerate:
Most Curious.
Couple of questions to aid in your diagnostics.....
BTW, I have a 1.6 DOHC of similar age;
Exactly what mileage do you have on the clock at the moment?
Has your MX-3 RS been doing this right from when you purchased it?
How many owners has it had?
What country are you located in? (Don't tell if you don't want to)
Do you have enough gear oil in your gearbox? Is it the correct type?
Have you had your running gear inspected? Loose rotors?
Could a part of your exhaust system be loose? (Clutching at straws here!)
Could one of those things that cushions the vibes between the engine and the body have failed? Rare, but if the engine was ever removed in the past and some incompetent nit botched the re-installation of the engine, one of those pads could be partially destroyed, hence your engine moves about under full thrust in certain gears and might induce this horrid noise.
Or maybe not. Just a lateral thought ok?
Hope I may have helped somehow
Thunderstorm
1998 MX-3 RS 1.6i DOHC "Blackbird". Totally Stock.
The 21st Century is a con; where is my Hovercar?!
http://www.cardomain.com/ride/2058708
Thunderstorm wrote:Hi fir3!fir3 wrote:My 1.6 dohc 97 mx3 has a very ugly and anoying and horrible knocking noise that happens when I accelerate:
Most Curious.
42.000 miles
yes
4
brazil
don't know if it is the correct type... would you suggest one ?
not yet...
I will check that..
I will check
Thunderstorm
- freyguy_412
