plumbing pipping size??
Joey's mx
Post by Joey's mx »
what size of pipping should i use for the plumbing on my turbo set up on my DOHC B6?? ALso what would be the best size of exhaust to run??
Post by Josh »
generally 2" on the turbo piping. some go with 2" to the IC then 2 1/4" from the IC to the intake you want it to be the same size or bigger than the exit side of your turbo. too big and you will see more lag.
exhaust
you just want to get no Back pressure. so anywhere from 2 1/4" to 3" ON A 1.6L will be perfect. i am running a 2 1/4" down pipe to 2 1/2" all the way back.
fieromx3
Post by fieromx3 »
also depends how much ur boostin if ur low boost 5-8 psi id go 2.5'' exhaust if ur goin well over 10 maybe like close to 15 or more 3'' to give better flow and also if u decide to turb the boost up more at least u got a good exhaust for it.
id go with 2.25'' on ur intercooler it will give plenty of velocity and little lag and flow good enough even for higher boost.
93' MX-3 GS-ZE
14.4 @ 96.7
14.5 @ 97.2
nos92mx3
Post by nos92mx3 »
im running 2.25->2.5 and im liking it.
92' Rs-t b6t/De - RIP
93' Rs-t BPT - Sold
03' WRB wrx Wagon - Current
Juans_93_MX3
Post by Juans_93_MX3 »
How about on a KLZE?
2.25 turbo piping and 2.5 exhaust?
2008 Mazda 3
1993 MX3 GS
jaydog5678
Post by jaydog5678 »
Juans_93_MX3 wrote:How about on a KLZE?
Whatever size you can squeeze in there. 2.25 is ideal.
Run 3" for the exhaust if you can live with a little more noise.
Juans_93_MX3
2.25 into a KLZE?
Wouldnt that be too small?
2.25 converted into MiliMeters is 57.15 which is about 2.85 smaller then the size of a KLZE throttle body (60mm)
How about 2.5inch piping (63.5mm)?
http://www.convert-me.com/en/convert/length
2008 Mazda 3
1993 MX3 GS
Return to “Forced Induction”
