Ok i need a Onesided intercooler...meaing both inlet and outlet are on the same side. This would make it cake to intall for the setup im doing. Now ive been on ebay and i found only one like what i need. But its too large its montrous.
So does anyone know where i can pick up a oneside intercooler...preferred size somwhere around 24 inches long 10 inches high and 2.5 inches width??
Looking for a intercooler but...
- XxantwawnxX
a 626 is something like that...
