Page 1 of 2
need rising rate FPR??
Posted: November 14th, 2005, 8:52 pm
by Joey's mx
Just wondering if i would need to run a rising rate fuel pressure regulator on a vj11 set up on a DOHC B6 at around 7-8 psi??? Or would a adjustable fuel pressure regulator be good enough with bigger injectors??
Posted: November 14th, 2005, 10:04 pm
by XxantwawnxX
I think FMU would be better..so you can run nice on boost..and not be rich as crap on idle. so yeah a rrfpr or fmu.
Posted: November 15th, 2005, 10:30 am
by babyblueMX3
rrfpr = fmu
Posted: November 15th, 2005, 12:00 pm
by XxantwawnxX
Yea when i said rrfpr or fmu...i did not mean one or the other...i meant there the same. Guess i could of worded it better.
Posted: November 15th, 2005, 5:36 pm
by Joey's mx
By FMU you mean like a s-afc??
Posted: November 15th, 2005, 5:48 pm
by XxantwawnxX
No an FMU is the same thing as a rrfpr (rsing rate fpr) which is just installed in series of your stock fpr. It uses boost pressure to raise the fuel pressure accordingly. For low boost operations i hear these work fine , im using one for my 4-6 psi boost configureration.
Posted: November 15th, 2005, 6:03 pm
by Joey's mx
Where would i find one and how much are they?? Dfoes it replace the fuel pressure regulator, or do i still use my adjastable fuel pressure regulator??
Posted: November 15th, 2005, 6:07 pm
by XxantwawnxX
You can find them all over ebay. I think vortec has some..and cartech. Usually i see prices from 100-300.
Posted: November 15th, 2005, 6:08 pm
by Joey's mx
do i still use my adj. fuel pressure regulator also??
by Joey's mx
Posted: November 15th, 2005, 6:28 pm
by XxantwawnxX
If im not mistaken, your adjustable FPR replaces your stock FPR right? If so then yes you can still use it. Just put the FMU in series with the adj FPR.
Posted: November 15th, 2005, 8:15 pm
by Joey's mx
ok thanks
Posted: November 20th, 2005, 12:02 am
by rukick
Posted: November 20th, 2005, 8:50 am
by babyblueMX3
huh ? where do you come from..the link you posted is for BEGI fmu ..the same one I used to run with
rrfpr = fmu !!
scroll down your page, click on :
Click here for the 2020 Series FMU
then tell me what are the first words on the other page.:
yeah that's what I thought.
Before telling somebody they're wrong, get your facts straight first
No offense
http://www.racetep.com/begireg.html
Posted: November 20th, 2005, 9:05 am
by Joey's mx
so would the fmu go before or after the stock regulator??
